1972 2.7 5-speed chassis # 00SB8419
Miles: 92,600 km (November 2010)
Exterior: AC 088 Blanc Meije
Owner comments
Chassis number: 00SB8419
Reg no: LJ 15304
Color: AC 088 Blanc Meije
Origin: France
Production year: 1972
Engine Number: 300808
Engine Type: C114 / 3, 2670ccm, carburetor
Interior: Black with gray carpets
Options: Leather seats, AC, tinted glass
Mileage: 92,600 km (November 2010)
Reg in Norway 2004
Jan Sverre Tronsmoen
922 35677
Retrieved car in Horten September 19, 2008 Mileage was then 85,000. The undersigned has made things as behoved appeared. Repair of alternator, fuel line, changed brake pads rear cuff for suspension cylinder front. Services like oil changes with filter, gear oil change, plugs and clean / adjust the carburetor and ignition. Rep paint rust. Mounted radio, the interior further. The change of glass for interior lighting. Adjusted toe and management. Rep window lift your right.
Curiosity: Engine number indicates that it is an IE-block in this vehicle.
The car was imported by Geir Gartmann in 2004 by Lars Frykholm in Sweden. Tailgate pane was broken so that he needed to change. The car was then "complete" with dark-tinted windows all the way. Clutch pump was repaired when the varnish. Relay for fuel pump broke so he had to disconnect the power to the pump directly.
Frykholm has completely restored car with register tensioner, exhaust valves, new AC compressor, exhaust, oil cooler, paint, krengingsdemper / hydraktivventil (XM), brake discs (front), new piston rings and clutch. Dark-tinted windows except the rear window, paint, tires, battery, alternator diodes, relays the light, start the engine and windows. New antenna, gas balls (around the) and pads (front). Carburetor has been modified from 3.0 liter engine (probably 180 hp).
Price in 1972: Kr. 162.000, - (Equivalent full funding of husbankhus same year).
Owner comments
Reg no: LJ 15304
Origin: France
Reg in Norway 2004
922 35677
