1973 Automatic chassis # 00SD1482
Postby hydropneumatic » October 20th, 2014, 7:51 pm
Sold $9,300 16 bids
Miles: 71,000
Seller Comments
Listing this Vehicle for a friend that has decided to sell his beloved Citroen. Is in good running condition. Runs good & smooth. Has good tires. All fluid changed last Fall. Air Condition & Heat work. Air Conditioning would need a recharge to operate. Has Automatic Transmission. Could used some restoration with new paint & some inside interior work. This was a second owner vehicle. The seller purchased this from the original owner in 1994. This vehicle is located in Central Wisconsin in Merrill Wisconsin. If you would like to view the vehicle, you can contact us & we will give you the sellers phone number so you can set up an appointment.
$_57 (14).JPG (194.36 KiB) Viewed 84512 times
