1974 3.0 Automatic chassis # 00SD0764
Postby hydropneumatic » February 4th, 2014, 8:49 pm
Ended February 3, 2014
Sold: $18,000
Temecula, California,USA
Miles: 35,500
Automatic transmission
Exterior: Silver
Your are bidding on a gorgeous original, rust free 1973 Citroen SM with 38,500 original miles on the original Maserati engine with automatic transmission, beautiful silver paint with rich cognac leather interior. This automobile has lived a charmed life in CA where it has never seen, rain, snow, or ice. It is a tremendous example of a 1974 SM and you would be hard pressed to find one in better condition that has not been fully restored. This car does not require restoring, it is simply a truly remarkable example of a 40 year old Citroen. This automobile is equipped with air conditioning as well as power windows, power steering and the original Citroen Radio with electric antenna. It also comes with a full set of original books, as well as service records. Only one blemish to the right front fender can be found on the exterior, interior leather is amazing and has no blemishes. SM’s I see for sale are usually within two spectrums – the restored version that cost between $40-$50K and the sitting in a barn for 40 year version. This is much closer and dare I say would rival any fully restored version but at a more reasonable price. This is an untouched and unmolested survivor that would be an incredible addition to any Citroen Collector's collection.
Although in top condition when it was purchased from the 2nd owner in Orange county CA in 2006, it was given what was needed the last few years: All work was performed by Paul/Rudy Helig at Citroen Concourse in Southern California and he can attest to the condition of this SM. Spent over $9,000 in the last 7 years to ensure everything was in excellent mechanical & original condition.
December 2006
R&R carburetors, water pipes, water pump, exhaust down pipes, pvc hoses
R&R rear timing chain, chain cover, tensioner & limiters
Replaced gaskets, seals, & water pump seals
R&R valve covers, camshafts & tensioners
Replaced cam chains & tensioner seals
Replaced circuit breakers
Replaced transmission oil cooler hoses
Replaced engine mounts
August 2007
Installed oil catchers for valve covers
Replaced front spheres with DS spheres
Replaced rear spheres with DS spheres
Installed new AC clutch & pulley assembly
Replaced jack shaft seal behind coupler
September 2013
Repaired power antenna
Rebuilt passenger power window motor
What it needs:
AC parts (New compressor, new AC hoses) but needs a new expansion valve.
Original radio stopped working last year
Receptacle for drivers seat belt needs repair
Needs new spare
$_57 (3).JPG (377.14 KiB) Viewed 43322 times
$_57 (2).JPG (359.24 KiB) Viewed 43322 times
$_57 (4).JPG (378.33 KiB) Viewed 43322 times
$_57 (1).JPG (372.98 KiB) Viewed 43322 times
