1972 5 speed Chassis #00SB8034
Postby hydropneumatic » January 20th, 2014, 10:03 pm
Ends January 25, 2014
$17,500 starting bid
Solon, Ohio USA
Miles: 51,532
5 speed transmission
Exterior: Sable
1972 Citroen SM. Second owner bought car in 1976. Has been stored for the last 6 years. Car was checked over and started right up with a new battery. Car runs great. Brakes work great, transmission shifts smoothly, hydraulics work perfectly raising the car up to 10" of ground clearance. Car may need right rear hub. Parts are available. Some rust starting on bottom of drivers door. Small ding in right rear bumper that is the bumper was taken off it would easily knock out. Rear seat has a split on one seam. Leather is not torn and in good shape. Tires have many miles of tread left. Less than 800 Citroen SM cars are in the United States. Has a 6 Cylinder Maserati engine with 3 Dual Webber Carbs. Car was years ahead of its time when made. Steering gets stiffer as the speed increases to prevent losing control. When new no other car was made that stopped faster. Front wheel drive.
Two owner car
